So today while on my way to work I was jamming out and decided to stop at a gas station for a drink. When I got back in my truck I noticed my sub wasn't working! When I got to work I hopped out an looked at everything and nothing seemed out of the ordinary. My amp was getting power, all the wires were hooked up. Just didn't wanna play. So when I got home I looked at everything again and this time I saw my amp wasnt getting power! So I'm stumped! Any help is appreciated!
Currently whipping a O4' GMC Sierra 2500
Performance:
K&N Cold Air Intake
Hedman headers
3" True duels
Flowmaster Super 10's
Magnaflow High Flow Cats
G2 4:88 running gears
New cooling system
Superchips Flashpaq programmer
Eaton lockers
Audio: JL CP208W3V3
Kenwood X500-1
8 Gauge Memphis Power wire
Kenwood DDX8901HD
Exterior:
Fabtech 9.5" lift
38x13.5 Toyo Open Country M/T's
18x10 Fuel Mavericks (-44 offset)
Diamond plate bed gaurds
Diamond plate tool box
Recon Xenon Bulbs in Highs,Lows,& Fogs
Recon LED Tail lights
AMP Research Automated steps
damn bro, so many factors...well, first check all your fuses, then check all your connections to make sure nothing came loose, then check if you're getting power to the amp with a DMM...ie: remote wire and power wire...make sure your grounds are good to..let us know how it checked out...
I think it's gonna be a fuse. Gonna check it as soon as I can.
Performance:
K&N Cold Air Intake
Hedman headers
3" True duels
New cooling system
Eaton lockers
Audio: JL CP208W3V3
Kenwood X500-1
Kenwood DDX8901HD
Exterior:
Fabtech 9.5" lift
Grab a meter and test for +12V at the amp's BAT and REM.
You using those glass AGU fuses under the hood? They like to fail without actually looking blown. The solder on the endcaps melts and creates a poor connection. +12V in one side and like ~2V out. It's the reason the entire industry is moving to the mini ANL design. One stamped piece of metal.
