So I noticed something funny with my electrical today, then discovered my 2 extra alternators stopped working... I'm having a real hard time figuring it out.
I clamped the positive wires going from the alts to the batter any I'm not getting much at all, revved up their only giving around 11 amps. The batteries are sitting at 11.4 volts so I know the alts should be charging them. I tightened up the belt and there is no slipping. Grounds are good. They worked just fine about a week ago when I hooked them up (each giving around 30 amps @ idle). I haven't taken them out yet to get them tested because its a bitch to get at them but even if they're fried I need to know why. Unless its 100% freak accident that both died at the same time (yeah right) I gotta get this sorted out.
Are alternators directional? They are spinning counter clock wise (just like the one in the civic), the alts are 130 amp out of taxi crown vics... any idea's or help would be appreciated. I cant run my stereo with only the stock 60 amp alt running. :angry:
regulators could have gone out, or a poor power wire?... there are few items that could cause both to go out or seem to be out at the same time
Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
I was thinking regulators too, but how and why? How do I make it not happen again?
I really gotta get this figured out, is there anyway to test the regulators?
Up!
Someone mentioned to me that maybe the regulators can tell that there is another alt powering the battery so they think its charged. Then the two aren't sending anything...
Come on! I know alot of people here are running dual triple or even quad alts.
Ooops I just noticed I put it in the wrong section, musta not have been thinking
Someone wanna move it to Electrical-battery- Alternators- Wiring :wub:
  • 4 weeks later...
Crown Vic... 3G or 4G alternators?
How are you connecting the regulators?
You can spin the 3G & 4G alternator either direction. There is a test for the regulator built in the back of it. If you look carefully, it says "Ground here to Test", with an arrow pointing at a hole. A wire in that hole, conected to ground will provide full power to the field -and full output. Be sure you are looking at your voltmeter when you test, and only do it for a few seconds.
If you killed the regulators, they are easy to replace. If you can reach the 4 screws that hold them in, you can do it on the car.
'Link
missinglinkaudio
The United States Marine Corps. When it absolutely, positively has to be destroyed overnight - even if "it" belongs to the base commander...
