Guest Posted April 29, 2015 Report Posted April 29, 2015 Ok cool, I am gonna test that tmrw! I will run like a jumper cable from front to rear on top of existing grounds to see if that helps. Hopefully this fixes it.. Hey broke do you think that having belt slipping can contribute to alternator whine or is that a separate issue?
Ahmed Johnson Posted April 29, 2015 Report Posted April 29, 2015 An easy way to test before run jumper cables is test the voltage at the back battery to the front battery. If you have very little to no voltage drop between the two while the car is running your grounds are probably good.
Guest Posted April 29, 2015 Report Posted April 29, 2015 An easy way to test before run jumper cables is test the voltage at the back battery to the front battery. If you have very little to no voltage drop between the two while the car is running your grounds are probably good. I will do that...shouldnt the rear battery's voltage read a tad lower? At least, I was told to connect my voltmeter to my rear battery basically for that reason.
Broke_Audio_Addict Posted April 29, 2015 Report Posted April 29, 2015 Yeah the rear voltage will be lower. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
Broke_Audio_Addict Posted April 29, 2015 Report Posted April 29, 2015 I don't think belt slip would cause the issue. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
Ahmed Johnson Posted April 29, 2015 Report Posted April 29, 2015 The rear shouldn't be that much lower.
Guest Posted April 29, 2015 Report Posted April 29, 2015 The jumper cable from the front to back did not work...
Ahmed Johnson Posted April 29, 2015 Report Posted April 29, 2015 Lol!!! You didn't even try to check the voltage between the 2 batteries before you did that, did you? Don't be afraid of the DMM it is a very useful tool.
Guest Posted April 29, 2015 Report Posted April 29, 2015 Lol!!! You didn't even try to check the voltage between the 2 batteries before you did that, did you? Don't be afraid of the DMM it is a very useful tool. The voltage is basically the same ..lol I use my dmm alot
Broke_Audio_Addict Posted April 29, 2015 Report Posted April 29, 2015 When you tested the jumper you moved the amp grounds right? That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
