Mrenglish90 Posted April 19, 2015 Report Posted April 19, 2015 Hey I'm new to the site and to subs / enclosures. I recently purchased some 10" comp D kickers. The suggested box volume is between 1.25 and 1.75 ft cubed. Currently they reside in a dual enclosure that i think provides around .9 cu ft for each sub. I would like to build my own ported enclosure to get the most out of the subs but being that i drive a mustang convertible i don't have a lot of space to work with. Does anyone have any ideas/designs i could use? I've thought about 2 single L shaped enclosure that would fit around the tire Wells, and also a larger dual box but i need help with measurements and box/port design. Any suggestions are appreciated.
yurvalentine Posted April 19, 2015 Report Posted April 19, 2015 Go grab a measuring tape and find out how much space you actually have.
Mrenglish90 Posted April 20, 2015 Author Report Posted April 20, 2015 Opening is about 11 x 47 and also has a drop which makes it bit bigger in the middle. Inner trunk space is about 26" deep 12.5" high and has two widths the front at 54" and the back at about 45". The depth between the tire Wells and the front of the trunk is about 11 inches.
Deeznutz Posted April 20, 2015 Report Posted April 20, 2015 Go to Walmart and get some boxes to mach up the biggest box you can put in there. That will give you the box size that the trunk opening will allow. I had to cut down my box from 34 to 28", something like that to make it fit in the trunk opening. I did a wheel,well sealed box for my 2 Memphis Audio C3 12s in a 96 BMW 328ic. -Frank
