dsw422 Posted April 19, 2015 Report Posted April 19, 2015 Hey all, looking for help with a box design using 2 power acoustik mofo 15s D2.. they'll b in a ford 500.. max dims are 17h, 30d, 38w... I'd like port center and subs back.. thanks 4 the help 2014 Ford Focus SE Sedan Factory Sony 10 Speaker Sound System 1994 Ford Bronco Dual head unit (i kno) Sony door speakers Kenwood Rear Speakers Custom Center console in the works. will house an NVX NSW10" https://m.facebook.com/WinnsCustomCarAudio/
Joe X Posted April 20, 2015 Report Posted April 20, 2015 Would need amp model and specific model for the subs.
dsw422 Posted April 20, 2015 Author Report Posted April 20, 2015 Amp isn't bought yet but will be for what subs are rated.. subs are power acoustik MOFO 15s dual 2 ohm 2014 Ford Focus SE Sedan Factory Sony 10 Speaker Sound System 1994 Ford Bronco Dual head unit (i kno) Sony door speakers Kenwood Rear Speakers Custom Center console in the works. will house an NVX NSW10" https://m.facebook.com/WinnsCustomCarAudio/
Joe X Posted April 20, 2015 Report Posted April 20, 2015 Ok MOFO-152X, you will need to run these either at 2 or 0.5 ohm so bear that in mind when getting the amp, the box very likely will need to be built inside: NOTES: power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 6 1/2", figure is just an assembly guide. NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
dsw422 Posted April 20, 2015 Author Report Posted April 20, 2015 Thanks JoeX 2014 Ford Focus SE Sedan Factory Sony 10 Speaker Sound System 1994 Ford Bronco Dual head unit (i kno) Sony door speakers Kenwood Rear Speakers Custom Center console in the works. will house an NVX NSW10" https://m.facebook.com/WinnsCustomCarAudio/
