Enclosure for 2x p2d2-12
masterkiwi
Hi guys,
I'm doing an enclosure rebuild because the last one was not correct.
Now i managed to find all Thiele Small specs but winISD is giving me some weird stuff..
I want to play vented 33Hz, anyone knows where to start?
11083740_822719997805973_344568651593822
Here are the parameters:
http://www.rockfordfosgate.com/products/details/p2d2-12
Also you use the manufacturer's suggestion as a reference not what the program suggests (as it is not made for car audio), to give you an idea of a sample spec for those subs:
4 cubic feet net total, 50 square inches of port area, ~23 inhes port length for a 33Hz tuning, speaker displacement is 1.61 liter per driver.
Alright, hoping someone could help me, is this OK for my subs? (Box is for one sub)
51.6Liters ( sub is 1.6)
Port surface: 130cm2
Port length: 43.5cm
Port type: blockport
Is this OK for ~33Hz?
So here is a suggestion for you, can use as reference or build, wood thickness is 18 mm, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 9 cm, figure is just an assembly guide:
NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
Wow dude, thats exactly what i was looking for!!! I wish i knew how you did the calculations..
Thanks for the work and thanks for the extra tip, will build it inside as i know it won't fit haha
You're welcome, consider getting the box in from the backseats, it may be possible, try to build the cardboard box and see what works, I can further modify the above so that you can build outside if you want.
  • Who's Online   0 Members, 0 Anonymous, 2967 Guests (See full list)
