Question about Aero Ports
i i recently built something different than i used to
a aero ported box
Thing is..can i GET THE SAME tuning frequency if I port the Aeroport OUTSIDE the box ?? like an External Aero?
Also..the lenght of the inside the box tuning would be the same as if i do it on the outside?
not asking any in particular just this..as if i do that i can get that extra space or not..just asking
2010 Chevrolet Cruze
Radio --- pioneer mvh-200vbt
Front/back --- alpine type s 6.5"
Sub Control --- Pac LC1
Sub Amp --- GZPA 1.4K
Sub --- GZNW 15XSPL D1
Battery - GZBP 12.2500X
ok..im using a port calculator..and if i do an external Aero..in the calculator do i mark as a number of ports at -1 instead of 1(as it would be normal if the aero would ba inside of the box???)
normally
Enter Enclosure Volume - 1.91x1.gif (ft3 )
Enter Desired Tuning Frequency - 40 Hertz Round Vent
Enter Desired Port Diameter
- 4 Inches
Vent Length - 8,21 Inches
outside the box???
Enter Enclosure Volume - 1,91x1.gif (ft3 )
- 4 Inches
Vent Length - __-14,21__ Inches
is that correct or am i mistaking something?
It's still 1 port. Just more volume. You won't notice the difference between the port outside or inside the box. It does increase efficiency slightly though
03 Sable LS
AA mayhem 12" D2
Sundown ZV4 12" D1
Tantric HD 12" D2
Tantric SHD 12" D1
Sundown X12 V2 D2
2.5 cu net
Sundown 2000d @ 1 ohm
XS Power XP2000
Sky High Sound Deadener
Sky High wire
Stock alt
Just do pi*r^2 x port length and add that to the box volume in your calculator and see what it does. Leave port at 1 and proper dimensions
tried but port lenght gets shorter by 0,6
just saying figure the volume of the port, add it to the volume of the box (if the box is already built) and then refigure.
but really, one 4" port at 9" is like .06cuft, probably wont make any noticable difference in or out of the box.
the volume is aprox 0,08cuft
that will change tuning like .5hz. that is if the box is already built and you are moving the port from inside to outside. If you havent built it yet you can accommodate. Did you figure sub displacement also?
