Box for Pioneer 5102 2500rms - 6000peak
Hi, first sorry for my english. Im from Uruguay. I have a pioneer 5102 12" 2500rms i need a box and need dimension (bass reflex) recomended. The car is a Vw gol 1999.
Thank you
Welcome, what's the amp, max dimensions for a box and what music you listen to. Also you need to find out the wood thickness you have avaliable in the 18-19 mm range.
Here is a suggestion either sub / port up or back done for 18mm thick wood, if you can't get it I can change it for other thickness, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 7 cm, figure is just an assembly guide:
NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
  • Who's Online   0 Members, 0 Anonymous, 3076 Guests (See full list)
