Best way to run 4/0 wire??
What's the best way to run 4/0 wire to the rear of a 1996 Yukon?? Underneath? Or through the Firewall and straight back?? And if underneath, where do I strap it to and what should I avoid? Also where would I come back up through??
Underneath.
Strap It to the frame rail and avoid anything that is hot or moves.
Sometimes you can even feed the wire down the inside of the frame rail.
How many runs are you doing?
