Advice On 2-way Active Sound Quality Setup
Woofer Pressure
My "go-to" budget, DIY, active suggestion is the Silver Flute woofers and Vifa xt25 tweeters. But you have plenty of choices.
Dayton RS180's are also very good.
Peerless
SB Acoustics
If you can fit the depth... the Anarchy is an absolute budget BEAST. http://www.diysoundgroup.com/anarchy-woofer/anarchy-4ohm.html
I don't think you can beat the Vifa ring radiators for tweeters since you have no size restriction and can get them on axis. They will also play low enough to mate with just about any woofer you choose.
Edit: since you're amenable to matched component sets... I have to toss in the Ampere Audio comps. I have them and they are lovely. They come in under budget too.
Thank you all for the input so far!
Unfortunately, the Anarchy woofers are a bit too deep to fit in my doors. Would the Silver Flutes be my next best choice?
Also, for the tweeter there seems to be a few different models. Which are you referring to?
https://www.madisoundspeakerstore.com/ring-radiator-tweeters/vifa-xt25sc90-04-ring-radiator-tweeter/
https://www.madisoundspeakerstore.com/ring-radiator-tweeters/vifa-xt25bg60-04-vifa-ring-dome-tweeter-double-magnet-4-ohm/
https://www.madisoundspeakerstore.com/ring-radiator-tweeters/vifa-xt25tg30-04-1-ring-radiator-tweeter/
TG30
