i need wall help!
thanks for the info. i understand port freq. i wasnt sure if a wall was the same as a simple ported box. i will buy my vehicle after i determine roughly how much space i need for my wall. thats why im looking for some software so i can play with some numbers.
2 mofo152x's on 6000 rms, 141.6 dB termlab
Winisd works pretty good!And you can download it for free.
I'm always opened minded and if there's anything you want to know, just ask!
I opened my first Car Audio Shop in 1993 and 22 years later, i'm still at it!
  • 4 weeks later...
These subs?
http://www.precisionpower.com/Manuals/Subwoofer%20Manuals/2010pcds.pdf
And this amp? Only shows rated power at 16v, doesn't even list what it does at 14 or 12.
http://precisionpower.com/store/products/amplifiers/pdx/pdx-10k.html
OP, if you can't even determine how to build and tune a simple box, you are in way over your head with a wall. Do yourself a favor and do some research and learning.
yeah those. The subs can only do 6400 rms anyway
i will be running at 16 volts
These subs?http://www.precisionpower.com/Manuals/Subwoofer%20Manuals/2010pcds.pdf
And this amp? Only shows rated power at 16v, doesn't even list what it does at 14 or 12. http://precisionpower.com/store/products/amplifiers/pdx/pdx-10k.html
Are you sure you are knowledgeable enough to run 16v?
if you only care about winning comps then build a few sealed boxes after you get the vehicle. build a faux wall and figure out what the car plays loudest at. Most people spend more on one sub amp than what a term lab costs. So go buy a term lab and test the way in which you will be competing will test.
now, that being said. SPL comps are rarely about music. So if you want to just be loud as hell on music by all means build a wall. If you just want to destroy everyone and win build a burp machine that is tuned to a perfect frequency for your ride and limit your power as much as you can so you can stay in lower classes and crush peoples dreams with your one note wonder.
So basically your options are, Save some cash, build a burp machine. or spend a shit load of money and time and build a musical nightmare that plays everything and can demos for days.
Did i get that right?
what is there to know. wire alt for 16v,
What do you think you need to run a 16v system?
do you know of some stuff I should know
  • Who's Online   1 Member, 0 Anonymous, 756 Guests (See full list)
