Just recently while driving/bumping, my zx2500.1 will cut off and cut back on repeatedly. Like it's not getting enough voltage, but it's getting over 14 v while driving. Funny thing is if I reset my headunit or switch sources (cd to ipod vice versa) it stops. Is this something that can be easily fixed. My warranty is very close to expiring and I do plan on selling it so I want to get an idea of what might be the cause and if I should send it in.
Thx
double check them ohm load to the amp, mine was doing it and the ohms were a little low but enough to cut the amp into protect mode, does it do it at low vol or only when you turn it up?
Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
when i turn it up. but it's only started doing it recently. and like the first 15-20 min of driving after that it stops.
thats odd, i know they have a protection circut that will put the amp into protect if the ohm load goes too low, (well my 850.4 does) but will operate fine at a low vol, turn it up and it will cut in and out, at higher vol... so like i said i would atleast check the ohm load and make sure you dont have a bad coil or sub gone bad
Ditto on what tracy said.
I had a hifonics amp that would cut out when I turned it up. It turned out that I had a bad amp ground. :) Regrounded it directly to some thick sheet metal (after sanding) and didn't have a problem.
Team B2, Team Audiotechnix, Team Kicker, Team XS Power, Team Sundown, Team Maxxsonics, Team DD2008 Bassrace 130-139.9 Regional and National Champion2006, 2007, 2009, 2010 and 2012 MECA Champion (S1, SR1, S2, S3, S4, DB1) -1 DD 9510F + 2 Sundown SAZ2500's @ .7 ohm strapped=154.2 headrest, 129.2 driveby-2 DD 9510F's + 2 Sundown SAZ2500's @ 1 ohm strapped=154.0 headrest-1 DD 9512F + 2 Sundown SAZ2500's @ 1 ohm strapped=153.5 headrest, 131.1 Driveby
-2 DD 9512F + 2 B2 Zero1's @ .5 strapped= 157.0 headrest, 158.0 outlaw-1 Sundown SA-8 + 2 MB Quart 2000's=148.8 headrest, 150.6 outlaw
  • Who's Online   1 Member, 0 Anonymous, 454 Guests (See full list)
