Toshe Posted June 7, 2015 Report Posted June 7, 2015 Hi! I want to build a ported box for my 2 SA-12s tuned to around 32 hz. Can you guys recommend some box designs? Car: Volvo V70 98 Max dimensions: w 111cm d 60cm h 40cm
Joe X Posted June 7, 2015 Report Posted June 7, 2015 Here is a suggestion for 22 mm wood as requested, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 11 cm, figure is just an assembly guide:
Toshe Posted June 8, 2015 Author Report Posted June 8, 2015 I was thinking about building with 21mm particle board.
Joe X Posted June 9, 2015 Report Posted June 9, 2015 If you can't get 18mm wood let me know to change it to 21mm.
