beanbo12 Posted June 10, 2015 Report Posted June 10, 2015 Got a newb question. Just got a explorer the other day and want to run some power and grounds. I want to do 2 runs of each positive and ground 0 gauge each to the back so I won't have to do it all over again when I upgrade to batts in the rear. Now my question can I use the ground. From my front Batt to my amp. I thought I read you would want the ground as short as possible. Or should I run it to the frame untile I get batts in the rear.
Lbox88 Posted June 10, 2015 Report Posted June 10, 2015 Take a multimeter and test to find a good ground in the back. I did the whole front to back ground before, it really does make a big difference having a real ground in back instead. UBL | Build Log
beanbo12 Posted June 10, 2015 Author Report Posted June 10, 2015 So your saying its better to have the ground in the back with the amps than the front to back method. When I get batts what would be the best way (grounding) From front batt to back batt or frame in back to back batt.
