02 dodge ram retro projector some detail
so far it was pretty easy heating the headlight to 250 degree 8min came right off just some pic will make vids when doing the other also should I paint them or not the flat white look good but my truck is that dark grey.
11402287_903843789678912_170580963238124
11022796_903843729678918_128805295061156
11426714_903843833012241_585326818541585
11415498_903843803012244_752019527696444
11393319_903843856345572_736067209537896
10535746_903843739678917_828202666408942
11357121_903843659678925_807384408315654
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
here a little more detail on how I did the retrofit on the dodge
I heated the oven to 250 degree for 8min on a pan the lens came off pretty easy next is all the cutting and grinding first take the glare sheld off the had to grind it down in order for the projector to fit.
169289_905281372868487_55505049588125970
10733387_905281386201819_536444169776837
I also drilled a hole where the glare sheld was for the HI switch
next had to cut where the 9007 bulb went and board the hole bigger
11222329_905281362868488_817207959091852
11312934_905281402868484_398658502214938
then put it on the truck to straighten the projector after the glue the lens back on the adjust the headlight
1913392_905281422868482_8343353512973662
1415449_905281439535147_8304939994319905
will update when I get them on the truck
2 sundown sd-2 d4
flex tech
box design by Joe X
