Jordan Thurston Posted June 15, 2015 Report Posted June 15, 2015 Ok I have 2 rockford fosgate punch 6.75 inch speakers up front that are 60 watts rms a peice and 2 punch 6x9s that are 75 rms a peice. I've been looking at the rockford fosgate prime r600-4 amp which is 100 rms x 4 at 4 ohms which is a little more than I need. I also was looking at the punch p400-4 which is 50 rms x 4 at 4 ohms. The punch amp is 9 bucks more than the prime but is it worth losing some power to get the punch amp vs the prime? Also the prime 400-4 is rated at 75 rms x4 at 4 ohms and thats about 50 bucks less than the other 2. What would you guys recommend?
Skullz Posted June 15, 2015 Report Posted June 15, 2015 Always choose more power if you can afford it. When you start pushing amps to their limits they'll create audible levels of distortion which you can avoid with more powerful amplifiers gained lower to keep distortion as low as possible. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
Jordan Thurston Posted June 15, 2015 Author Report Posted June 15, 2015 Ok so should I go with the prime 600-4 even though it's the entry level rockford amp? Are the prime series ok ?
Skullz Posted June 15, 2015 Report Posted June 15, 2015 Should be a good amp for those speakers. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
Jordan Thurston Posted June 15, 2015 Author Report Posted June 15, 2015 Ok thanks I think I'll go ahead and order it tonight.
Jordan Thurston Posted June 15, 2015 Author Report Posted June 15, 2015 Should be an improvement from the 1400 watt crunch amp im using now it distorts bad at high volumes and gets really hot
