First one is pertaining to what is a better place to connect my 1/0 wire. First option directly to the battery. & second option is a red box that is connected to the battery & is where the alternator sends its power to the battery. I've up until now always used this redbox to get power to my amps, but im starting to wonder if it makes a difference between there & the battery. I ask this now because i'm doing a run of wire and don't want to cut it and then find out it should be the other option and have to redo it because it wasn't done correctly first. Pic's to follow
B1CF6FDB-D486-4BC9-B2C4-23FBC4A0E0F7_zps
02F96DAC-3A49-4B7D-B5A9-B0FF5464E466_zps
Second one is regarding the box's that i plan to use. I was going to do two separate ported box's tuned to 35hz with about .7 cft of volume after displacement. (DC Audio M3 8") But is this a bad idea? Im just wondering if there could be noises added in from the subs not being in the same box.. Any idea's?
  • Who's Online   0 Members, 0 Anonymous, 1499 Guests (See full list)
