Install 6.5s and amp Help!!
Not really. I mean I can but it was a whole deal getting it in. And I don't remember it was so long ago. Any sure way to run if I only have a single positive and single negative RCA run? I have more to connect the amps but it would simply be one run of rca's to the last amp
It really depends on the RCA output though. If it's only a single sub out on the back, then you won't have the mids and highs signals coming through it due to the filtering process in the head unit. What's the model number of the head unit?
jvc arsenal kd-ahd59
Ok so from looking at the specs, you have a sub level out, and a line level out. Use the 2 for the sub out for your sub amp obviously. And the 2 for the line level out for your 4 channel. You'll have to get some y-splitters (one female to two male).
