rumblefish Posted July 11, 2015 Report Posted July 11, 2015 I'm considering trying out these for my Tahoe. Obviously space isn't a huge consideration. Max dimensions are 48w x 16h x 28d. I haven't seen much in the way of box recommendations for these. I listen to a lot of metal,(Tool, Slayer) and I also like some rap for fun. I could go deeper and higher if needed. Any suggestions guys? Thanks. I was also thinking about aeroports for a change. Thanks. 02 Tahoe, pioneer 880, quart qsd 216's, skar vvx 12's, sundown sax 100.4 and 1500dv2
Joe X Posted July 11, 2015 Report Posted July 11, 2015 It could be done as follows, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 6", figure is just an assembly guide:
rumblefish Posted July 19, 2015 Author Report Posted July 19, 2015 Thank you Joe. That's definitely workable. I should have said max width of 49". The local sheets of MDF are 49 x 97. It would simplify my cuts quite a bit. You already did me a solid with the listed design. If you have a chance could you take a look at the design with a width of 49"? Again, thank you for your time. 02 Tahoe, pioneer 880, quart qsd 216's, skar vvx 12's, sundown sax 100.4 and 1500dv2
