GorillaFIngeRs Posted July 19, 2015 Report Posted July 19, 2015 I just got a new XS power battery for under the hood. I have seen that you should give them a full charge before installing them. Is there anyone in the Sacramento area that has a charger that would be willing to let me get a charge? I am willing to pay if need be but I just want to make sure I take care of this batt so that it will take care of me. AQ3500.115" Fi SP41/0 Knuconceptz Power/Ground 1/0 Sky High Big 3 UpgradePioneer AVH-4200NEXXS Power D1200 Underhood Intimidator Gel In Trunk CES 250A Alternator
moredbs Posted July 19, 2015 Report Posted July 19, 2015 if you have a dmm, check the voltage. if its 12.6 or up, you should be good to throw it in. the last one i ordered was resting at 12.9 when i opened it up.
GorillaFIngeRs Posted July 19, 2015 Author Report Posted July 19, 2015 Sitting at 12.82v sounds good to me. I can't wait to get this thing in. I've been battling distortion issues for a while I really think this is going to be my resolve. Big 3 and batt should be in this week and I couldn't be more excited. AQ3500.115" Fi SP41/0 Knuconceptz Power/Ground 1/0 Sky High Big 3 UpgradePioneer AVH-4200NEXXS Power D1200 Underhood Intimidator Gel In Trunk CES 250A Alternator
08tahoe Posted July 19, 2015 Report Posted July 19, 2015 Like moredbs said if your above 12.6v then your good.. But a new battery is not going to fix distortion issues.
GorillaFIngeRs Posted July 19, 2015 Author Report Posted July 19, 2015 With the voyage drop I am getting it should make a significant difference. I've done everything to this point except a batt and big 3. I'm only running 1000w so an alternator shouldn't be needed. After tuning my amp with a DD-1, and running 1/0 wire. I have found that when I play my sub in the higher volume my VC gets extremely hot. I also found my voltage getting into the 12.4 range. With a battery that should keep me up in the 13v range I can see this making a big difference. AQ3500.115" Fi SP41/0 Knuconceptz Power/Ground 1/0 Sky High Big 3 UpgradePioneer AVH-4200NEXXS Power D1200 Underhood Intimidator Gel In Trunk CES 250A Alternator
GorillaFIngeRs Posted July 19, 2015 Author Report Posted July 19, 2015 I plan on making a video for a before and after test. I will post my results to either prove or disprove my theory about voltage drop/current rise Vs distortion. AQ3500.115" Fi SP41/0 Knuconceptz Power/Ground 1/0 Sky High Big 3 UpgradePioneer AVH-4200NEXXS Power D1200 Underhood Intimidator Gel In Trunk CES 250A Alternator
GorillaFIngeRs Posted July 19, 2015 Author Report Posted July 19, 2015 I did not AQ3500.115" Fi SP41/0 Knuconceptz Power/Ground 1/0 Sky High Big 3 UpgradePioneer AVH-4200NEXXS Power D1200 Underhood Intimidator Gel In Trunk CES 250A Alternator
08tahoe Posted July 19, 2015 Report Posted July 19, 2015 It will help because if you dd-1 with the car off your voltage will be at batt power so if your voltage drops it won't distort untill you hit batt voltage if your dropping low.
GorillaFIngeRs Posted July 21, 2015 Author Report Posted July 21, 2015 Very good. I will retune that way. This goes against everything I've read. But it makes sense when you put it that way. I'll try anything at this point. AQ3500.115" Fi SP41/0 Knuconceptz Power/Ground 1/0 Sky High Big 3 UpgradePioneer AVH-4200NEXXS Power D1200 Underhood Intimidator Gel In Trunk CES 250A Alternator
