poorfish88 Posted July 20, 2015 Report Posted July 20, 2015 wow im dumb lol i overthinked the impedence my bad lol... so not strapping them would be better then?also if i dont strap them then should i just use an rca splitter for the amp inputs? 1st time running more than 2 amps for bass sry The Cresendo 3500 has RCA outputs so, if your dont strap the amps you could use the RCA outputs instead of a splitter. Either way works fine.
Tyler Morse Posted July 20, 2015 Author Report Posted July 20, 2015 wow im dumb lol i overthinked the impedence my bad lol... so not strapping them would be better then?also if i dont strap them then should i just use an rca splitter for the amp inputs? 1st time running more than 2 amps for bass sry The Cresendo 3500 has RCA outputs so, if your dont strap the amps you could use the RCA outputs instead of a splitter. Either way works fine. so i can just run the rca outputs from 1 amp to the inputs of the second? sry like i said new to this im trying to learn everything i can about it...
poorfish88 Posted July 20, 2015 Report Posted July 20, 2015 Yes, the Cresendo 3500 has RCA inputs and outputs, so you can wire either way. You can use a splitter and use the RCA inputs on both amps. Or run the RCA input to one amp then use the RCA output to connect to the RCA input of the other amp.
Tyler Morse Posted July 20, 2015 Author Report Posted July 20, 2015 Yes, the Cresendo 3500 has RCA inputs and outputs, so you can wire either way. You can use a splitter and use the RCA inputs on both amps. Or run the RCA input to one amp then use the RCA output to connect to the RCA input of the other amp. nice! that seems simple enough thank you you have been super helpful for me
