Can someone make me a custom enclosure design?
guttagfx
Wow im on my cell but that looks really good cant wait til i get off work to check it out on my monitor. This is based on 3/4" mdf wood right? Also once its built should i get it proboxed (sprayed with rhinoliner) or is it best just get it upholstered?
No problem.. yes, 3/4"mdf..
Covering the box is up to you.. if u like rhino liner, then go for it.. either way doesn't effect sound, just looks..
2014 Ford Focus SE Sedan
Factory Sony 10 Speaker Sound System
1994 Ford Bronco
Dual head unit (i kno)
Sony door speakers
Kenwood Rear Speakers
Custom Center console in the works. will house an NVX NSW10"
https://m.facebook.com/WinnsCustomCarAudio/
Box is done, i messed up some cuts after some beers, but next day and another mdf 2'x4' later here are the results...what do you recommend for some of the uneven-ess and small gaps? or should i just toss it and start over?
Gaps inside should either be fiberglassed or siliconed. I'm gonna recommend fiberglass simply because of the odd angles (for strength)... Outside the box, body or wood filler and sand smooth..
Did u put the port in??
1994 Ford Bronco
Sony door speakers
  • 3 weeks later...
  • Who's Online   0 Members, 0 Anonymous, 3292 Guests (See full list)
