low fps on high end machine
I remember something like this happening on my pc after an update and the I think super sampling or something to that effect where it tried to double the resolution vs the pixel count effectivly doubling it and puttin a big strain on games
FSAA could be turned way too high, yes. At 1920x1080 2x should be ok..
tuba - Check that your card is not overheating and dropping the GPU clock. MSI Afterburner using the on-screen display helps with this (or GPU-Z, it will log high and low temps and you can check high temps after gaming). You can manually adjust the fan profile if that is the issue. Alternately the issue could be FSAA or your PSU is a bit weak.
Hammerdown... 1%
What update was this? A GPU update?
2009 Dodge Caliber SXT (Silver)
Deck: Pioneer X3600BHS
Amps: RF P1000X5
Front: RF P16-S
Rear: RF P1694
Subs: 1 RF P3D2-10
Cabling: Stinger 6 channel RCA, RF 4gauge kit, SkyHighCarAudio 16gauge speaker wire.
Build Log: http://www.stevemeadedesigns.com/board/topic/188246-caliber-build
Professional Networking: https://www.linkedin.com/in/kade-mallett-332b8a104
I 2nd that.
Amps: RF P1000X5
Front: RF P16-S
Rear: RF P1694
Subs: 1 RF P3D2-10
He might be thinking of VSR/DSR which essentially allows you to emulate higher resolutions through the graphics driver.
Hammerdown... 1%
