Jeradmp Posted July 27, 2015 Report Posted July 27, 2015 I'm building a 5000 watt system for my best friends little brother for his first car. He got carried away with my credit card and ordered 5 XS Power batteries thinking more juice = more noise... So what do I do and how do I go about it??? We have a single 250 amp Singer alternator (only 1 will fit and the only one I could find for an 88 bronco), do I run them all parallel with each other from the front to the back, all parallel together??? Or do I have to run a charge wire off my alternator all the way to the 4 batteries in the back in the back and run them parallel??? Or am I completely off... I need tons of advice and help.. All info would be greatly appreciated!!!
mrdavebasshead75 Posted July 27, 2015 Report Posted July 27, 2015 First you should do the big 3! Then run a run of 1/0 to the back pos of your battery bank. You can run the charge lead from the front batt and make sure you fuse up front as well. You should be ok with 1 run. Wire all batts in the back pos to pos and neg to neg, make sure you have a good ground location for your batts. I run 3 xs batts and grounded each batt to the frame as well as connected each batts neg together. What exactly are you running? Subs? Amp? http://www.stevemeadedesigns.com/board/topic/141026-2001-bravada-build-2-15supdated/?fromsearch=1 ----old build!! http://www.stevemeadedesigns.com/board/topic/194247-2005-chrysler-300c-buildslowwwww-lol/ -----new build!!
khinds94 Posted July 27, 2015 Report Posted July 27, 2015 Do a run of positive from the front to the back battery both positives together. And then from the back, wire the rest positive to positive and negative to negative 03 Sable LS AA mayhem 12" D2 Sundown ZV4 12" D1 Tantric HD 12" D2 Tantric SHD 12" D1 Sundown X12 V2 D2 2.5 cu net Sundown 2000d @ 1 ohm XS Power XP2000 Sky High Sound Deadener Sky High wire Stock alt
Jeradmp Posted July 27, 2015 Author Report Posted July 27, 2015 Thanks doe the advice man!!! 3 Fi Q fully loaded and optioned, 1 Rockford t2500bd' at 1.3 ohm, Rockford T1000-4 for the components and T800-4 for the tweeters... It has 8 component speakers, and 8 additional tweeters. D3100 under the hood and 4 XS xp3000 in the back...
