Rate my 4th order design please.
My buddy at work who had a sealed box for his RE SeX 12 blew a sub and decided to replace them all with SQ HDS3s and they are quite a bit louder than the REs and he's curious to see how loud he can get em. I'm gonna build him a 4th order bandpass that will fit between the wheel wells and use the existing equipment.
What do you think of my plans?
Current Setup : Nothing
2014 Ford Focus SE Hatch
Future looking like:
Singer / XS power
Crescendo BC3500D
CT EXO 15
Pioneer 80PRS
CDT HD-61PRO
CT Sounds M75.4
CT Sounds AT60.4
Something along those lines.
It's not to scale btw.
Oh and a 2x4 will be dead center of the box as a brace.
Singer / XS power
Crescendo BC3500D
CT EXO 15
Pioneer 80PRS
CDT HD-61PRO
CT Sounds M75.4
CT Sounds AT60.4
What vehicle?
With that large of a front chamber, its going to have peaky output. If you are going for numbers, that's probably to your benefit.
Builds:
Blow through 2007 Ext cab silverado.
I have another guy telling me to go for 1:3 ratio. I just want a loud but still musical sound. Mostly rap music. Its not an sq setup but the subs are currently sealed and give great response across a wide frequency range. I want to keep as much musical ability as possible while blowing the doors off the sealed spl.
Singer / XS power
Crescendo BC3500D
CT EXO 15
Pioneer 80PRS
CDT HD-61PRO
CT Sounds M75.4
CT Sounds AT60.4
What vehicle?
I have to disagree with you there.
I've done many 2/1 or 2.5/1 ratio 4th's that are within 2 db from 30Hz-60Hz
TEAM SOUTH Bassahaulic Productions
The ONLY Bright Atlantic Blue DiamondBoxx L
Drew Jones
4 SSA ZCON 15"s
2 Sundown SCV-6000's
6 AGM G31's
161.6 @ 40Hz Outlaw
159.8 @ 36Hz Legal
┌∩┐(◣_◢)┌∩┐
What vehicle?
You know what, I don't doubt you one bit.
This is the problem with bandpass box "ratios", and why I do not like them, they tell you NOTHING. Notice that I did not say, "it's going to be peaky because it's a 2:1 ratio (roughly)" I said it's going to be peaky because the front chamber is so big.
If we were to double the size of the rear chamber, that box would have a less than 1:1 ratio, but would it sound less peaky? No it would not. Conversely, if we were to cut the rear chamber in half, it would then have an almost 4:1 ratio, so would that make it have a larger peak in output? Again, not really, it would just make the low end roll off a little more steeply.
"Ratios" are completely meaningless!!!! I wish I could banish them from the car audio world's collective memory. You can't take one metric about and bandpass box and expect it to tell you anything!!!
Here is the simulated response of that box:
The graph doesn't include any cabin gain effect, which will boost the low end output a bit.
Peaky is different things to different people so its up to each person to interpret how that looks, but it looks like a pretty big damn peak to me.
So I have a question for germanyt, how did you come up with the specs for your design? Did you simulate the output to get those numbers?
Builds:
Honestly i used a 1.5 cubes per sub and 2:1 ratio with tuning higher than 45hz. Thats pretty much it.
Singer / XS power
Crescendo BC3500D
CT EXO 15
Pioneer 80PRS
CDT HD-61PRO
CT Sounds M75.4
CT Sounds AT60.4
Does that graph mean ill have peak output between 30 and 90 hz? Cuz that would be awesome.
Singer / XS power
Crescendo BC3500D
CT EXO 15
Pioneer 80PRS
CDT HD-61PRO
CT Sounds M75.4
CT Sounds AT60.4
Your peak is pretty much going to be right around your tuning frequency, so 46 Hz. Its a pretty big peak so the box may not be as musical as you would like. Though different people have different opinions on just what "musical" is.
Builds:
My understanding of a 4th order is that tuning frequency is where youll see drop off in output. So this box would be loud from whatever lows the sealed will allow up to 46 hz. Not the case?
Singer / XS power
Crescendo BC3500D
CT EXO 15
Pioneer 80PRS
CDT HD-61PRO
CT Sounds M75.4
CT Sounds AT60.4
