we_drop_bass Posted August 13, 2015 Report Posted August 13, 2015 Anyone have experience putting these in a box on the small size of the recommended specs. Thinking about putting a pair of 18s in a little over 11 cubes tuned to 32/33 with ~14 sq in port per cube. Website dictates 5-8 per woofer at 33 with 12-16 per cube This is just a daily setup, in the back of a Yukon Denali likely powered by scv 6000, unless another 6kish amp catches my eye. I listen to some rap, some dubstep/other electronic (like bassnectar) and quite a bit of metal and hard rock 2008 Denali Singer 270 2 XS D3400s under hood Sundown SCV-6000D SHCA 1/0 Q Logic Kickpanels - lame 5.25 components for now ..... Planning/acquiring everything else
we_drop_bass Posted August 15, 2015 Author Report Posted August 15, 2015 Bump?... I know typically anywhere within manufacturer specs is fine, but 5-8 cubes is a wide range... Just hopin someone had tried it on the small side 2008 Denali Singer 270 2 XS D3400s under hood Sundown SCV-6000D SHCA 1/0 Q Logic Kickpanels - lame 5.25 components for now ..... Planning/acquiring everything else
Triticum Agricolam Posted August 15, 2015 Report Posted August 15, 2015 A larger ported box is going to give you more output around tuning, buy may be more peaky. A smaller box will probably have smoother output. Neither size is right or wrong, it just depends on what your personal listening tastes are. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Miguels Posted August 15, 2015 Report Posted August 15, 2015 i have a pair of 18's in a 12.5 cuft after displacement and they do good my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
