6XW6 box help
Yes the baffle area is enough to fit the subs but you should have about 5-6" clearance to the rear gate, also the smaller box may not be ideal for a comps setup.
Here is a suggestion, pretty much the only way given your space constraints, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 6", figure is just an assembly guide, bracing is 1 1/2" wooden dowel rods:
  • Who's Online   0 Members, 0 Anonymous, 4258 Guests (See full list)
