beanbo12 Posted August 15, 2015 Report Posted August 15, 2015 Looking for a box design for two ht18's. It will be in the back of a 2001 ford explorer, powered by a 1600.1. My max dimensions are 41" wide 26" depth and 24" high. If any Wher can move it would be the depth and hieght. I can post the specs if anyone would like. Thanks I'm advance.
beanbo12 Posted August 15, 2015 Author Report Posted August 15, 2015 HT18 Dual 4 ohm HT18 Dual 2 ohm Re ohms Re 3.5 ohms Fs Hz Fs 17 Hz Qes Qes 0.41 Qms Qms 5.8 Qts Qts 0.38 Le mH Le 3.2 mH Sd mm^2 Sd 117841 mm^2 Vas L Vas 411.9 L Bl Bl 19.7 Mms g Mms 416 g Cms Cms 208.8 Sensitivity. db 88.7 Xmax mm Xmax 22.5 mm From what I got off their site both 2 ohm and 4 ohm are the same I guess. Getting 2 of the dual 4 versions to run at 1 ohm to my amp. I like the lows.
Joe X Posted August 16, 2015 Report Posted August 16, 2015 Here is a suggestion almost in your max dims, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 5 1/2", figure is just an assembly guide:
beanbo12 Posted August 16, 2015 Author Report Posted August 16, 2015 Thanks joe x. For the box but the max on the width is 41 I can't fit 43.5 between the wheel wheels in the explorer. The only things that can move is the hieght and depth.
Joe X Posted August 16, 2015 Report Posted August 16, 2015 Updated, bear in mind that you still need 5 1/2" port clearance, this is to the closed rear gate.
