Maybe just run all red or all black wire to the speakers? I think that would look better personally. Either way, awesome build man!
the subs have direct leads and i didnt want to cut them much incase of another install
i could solder on new ones each time but thatd be some work.
thought of running them down the one screw hole by the terminal but the outside ones wont reach.
and you have to have the 3 center subs out to connect the inside of the terminals. so it would be quite a juggling act balancing a sub with the wires through the hole, solder on a ring terminal in the box, connect it and then screw the sub down
Follow Seth Sharer Designs on Facebook for more frequent updates!
New build coming soon!
20 6.5s wall on two massive drago 5ks
got the new stereo in! and a video of the subs playing. cant turn it up too much, dont have the electrical yet. but hopefully when i get it all back together it will be ready for SOTM! FINALLY!!
  • 2 months later...
so ive just about got the build wrapped up, needing an alt and a few minor things
but ive started brainstorming.
i went overkill on the electrical(and glad i did) i can support about 5k with the alt i plan on getting.
well just so happens i did a little measuring and can fit 20 6.5s, on a 4-5k amp
YES 20 6.5s!
little c pillar wall build? i think YES!
so the first model(just a rough idea)
and then a little color
and finally added some bracing
so this is what the end result should be(still may be a few tweaks)
right at 10 cubes, 3 6 inch aeros tuned to 36
  • 3 months later...
Haven't posted in a while so here's an update.
NEED EVERYONE'S VOTES FOR SOTM!! MECHMAN ALT UP FOR GRABS AND I NEED IT!
Here's some recent pics!
received_1307296899286000_zpsnshtk5gp.jp
REALLY NEED THIS ALT GUYS! NEED YOUR VOTES!
  • Who's Online   0 Members, 0 Anonymous, 2038 Guests (See full list)
