SA-15 Box
JKJ752
Hi I recently acquired a used SA-15 and it came with a box. It sounds decent now, however the box smells quite bad and I think a bigger box better suited for it would be better. The car the box is going into is a PT Cruiser and I have room for a box to be around 38 inches wide, 18 inches deep and 20 inches tall. If needed the box could be slightly taller or deeper but I would need to make sure it would fit first. I mostly listen to rock/metal and some pop/ top 40 songs and maybe a little bit of rap. The amp I am using is a Kicker zx750.1 wired to a 2 ohm load with a 25hz subsonic filter. Any feedback is greatly appreciated and if someone suggest a box design I will be sure to post pictures of the box after however it may not look the best as this will be my first box build so I will probably manage to mess something up. Thanks again, Joe.
So here is a suggestion, your previous box was about 2.3 net (from the data provided) which is well below minimum spec, the following will reach lower and be more efficient (so louder per watt) , power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 3 1/2", figure is just an assembly guide:
Any questions or changes, let me know.
  • Who's Online   0 Members, 0 Anonymous, 465 Guests (See full list)
