betweenmatt Posted September 11, 2015 Report Posted September 11, 2015 Hifonics bxi 1206d, I've had it for about 9 months running 1 ohm at 1k watts. Last night I started her up and she sounded disgustingly underpowered like only one of the subs were working, though all 4 where moving. I checked the resistance of all the subs, checked all the connections, switched out the deck in case the previous outs went bad, checked for shorts and checked for blown fuses; everything checked out fine. When I check the speaker outs with my dmm it's reading around 5 volts ac on full tilt, turning up the gain just adds distortion. Am I sol? Google hasn't been much help :/ if it's even remotely fixable I'd like to take a shot at it since I do have a bit of experience working with electronics and a soldering iron. I just want to exhaust all my options before I take it on a potential death trip lol Thank you for your time!
betweenmatt Posted September 12, 2015 Author Report Posted September 12, 2015 No one here has had this happen before?
Wicks Posted September 12, 2015 Report Posted September 12, 2015 Play a test tone full tilt with the RCAs disconnected. What's the output of the head unit? What are the subs wire at? What do they measure with an ohmmeter? Amp get hot? Grounds good? Connections tight? Fuses blown? How were the gains set previously? This post sent with 100% recycled electrons. 2004 BMW M3Mechman 280A 2 - XS Power XP30001 - XS Power D375 500F of Maxwell SuperCaps (soon to be 1000F) iPadMini2Dash mounted O-scopeAudison bitOne (Remote DRC MP) Highs Amp - PPI Art A404 Hertz HSK130 (HSK165 waiting...) DC Audio DC9.0K 2- DC Audio XL12m2LEGAL - 147.3dB @ 41Hz OUTLAW - 150.2dB @ 45Hz OUTLAW - 145.7dB @ 30Hz JUNE 2014 SOTM WINNER 2014 COLORADO PEOPLE'S CHOICE WINNER SOTM BUILD:http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
betweenmatt Posted September 27, 2015 Author Report Posted September 27, 2015 Sorry my car was totalled right when you responded and I finally got a replacement to put my system in xD. I swapped through 3 separate sets of rca cables and I used the same outputs on my 4 channel amp and it's putting out power like normal so it's not the rcas sadly. Amp never got hot, sometimes a little warm to the touch but never alarmingly hot. Ground was good, 1/0 gauge bolted tight to sanded down frame. I checked all the connections numerous times. Not a single fuse was blown. The gains were set at 30v ac with a 50hz tone. The subs are wired to 1 ohm. I just cracked it open, but I don't see any noticeable damage, I'll post a pic in a minute maybe someone can see something I missed :/ I really hope I can revive this amp since I had to buy a new car I can't afford a new amp anymore q.q
betweenmatt Posted September 27, 2015 Author Report Posted September 27, 2015 http://s7.postimg.org/tyndz9avv/20150926_213633.jpg Sorry I couldn't figure out how to post a picture here on my phone lol And the bottom left Mosfet in the picture isn't scorched, it's just grease or solder paste or something
Deeznutz Posted September 27, 2015 Report Posted September 27, 2015 Unfortunately Hifonics are known to only last a few months. They're stepping-stone/gateway amps. Looks like you're going to have to look for and save up for a more reputable amp manufacturer. Audiopipe is right up there with Hifonics, so no sense in looking at that brand either. Good luck. -Frank
