dual 15 Memphis Mojo enclosure
Bingo6104
Thanks Joe for the quick reply. If you need anymore info let me know. I greatly appreciate this a lot!
Vehicle : 2004 Jeep Cherokee
Music type: Old school rap,Hiphop and metal like Korn ,FFDP etc and of course some bass music :) ( is this need for tuning specs?)
15mojo515d4
Sub specs:
Impedance (Ohms) 2 (Dual 4 Ohm)
DCR Per Coil (Ohms) 1.73
Resonant Frequency (Hz) 27
Mechanical Q (Qms) 4.4
Electrical Q (Qes) 0.72
Total Q (Qts) 0.62
Linear Xmax (in) 0.66
Linear Xmech (in) 1.29
Sensitivity @ 1W/1M (db) 85
Effective Piston Area (SqM) 0.085
Vas (Cf.) 2.43
Moving Mass (Grams) 523.15
Motor Strength (T/M) 14.55
CMS (um/N) 66.4
Voice Coil Diameter (in) 3
Recommended RMS Power (Watts) 1750
Maximum Peak Power (Watts) 3500
Magnet Weight (oz) 196
Cut-Out Diameter (in) 13.9
Frame Diameter (in) 15.4
Mounting Depth (in) 8.86
Driver Displacement (Cf.) 0.389
Amps
Currently just one db drive 1200.1 class d I plan on running either one big amp or 2 smaller amps to the subs. Not sure on what wattage i will push yet. Open to suggestions and opinions on this???
  • 4 Ohms @ 14.4 Volts - 1 x 600 Watts
  • 2 Ohms @ 14.4 Volts - 1 x 1200 Watts
  • Subsonic Filter - 15Hz-55Hz
  • Capability - 2 Ohms Mono
Max dimensions :
Width 41 inches to fender wells
Depth: 27 , leaves about 7-9 clearance to the back of the hatch,
Height : 20 would be max if need, if possible 17.5-18 would be ideal height even with the top of the back seats.
So here is a suggestion, power: to sub(s) rated, amp subsonic filter to 28Hz, minimum port clearance 5 1/2", figure is just an assembly guide:
The brace for the port, I don't think it's on the cutout sheet. Looks like it is 3 or 4 inches in then the depth of the port ? I guess it's not critical for the measurements if it's not in the cutout sheet?
Use the same MDF as the rest of the box, dimensions are the same as the sides of the port, just for aesthetics you can make it a little shorter as the figure suggests.
  • Who's Online   0 Members, 0 Anonymous, 1072 Guests (See full list)
