alaskanbass Posted April 14, 2008 Report Posted April 14, 2008 why does it have two + two - and two rem for it.. do they all need to be hooked up.. kinda weird.. clarion cz500 head unit Kinetik hc600 2 level 3 15s in a 4th order mb quart 1500.1 (for now untill i get a dc 1.2k) all knu konceptz wiring in a 2009 ford flex -DISKOLORED AUDIO- -Authorized Dealer for DC Soundlab in Alaska-
dleccord Posted April 14, 2008 Report Posted April 14, 2008 yeah i never get why they put two remote wires for one amp with two power supplies. refs: chode69, superduper
Boon Posted April 15, 2008 Report Posted April 15, 2008 The amp is a dual power supply design. It's REALLY important that you power up both +'s and both -'s or the amp may crap itself. I don't know about the REM's... it seems odd to have 2 because they are very low current anyway... try putting a multimeter across them on resistance, if it's 0 ohms they're connected internally... 10.x volts fo' life!
jayjay6888 Posted April 15, 2008 Report Posted April 15, 2008 i always thought that dual power supply amps where.... one for main power(battery) and ground and the other power supply was just a built in spot for the capacitor... im not sure about the orion but its like that on the MTX TA series 1 Fi Sp4 18 Crescendo 2k selenium mids audioque supertweets Hifonics for mids and and highs 1/0 power and grounds ---> on the way singer alt and possibly another 2k depending how sub likes 1 2k
dmanson Posted April 15, 2008 Report Posted April 15, 2008 i always thought that dual power supply amps where.... one for main power(battery) and ground and the other power supply was just a built in spot for the capacitor... im not sure about the orion but its like that on the MTX TA series it's the same on the 95-98 RF Punch amps too. sort of elminates a distribution block. 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
Boon Posted April 16, 2008 Report Posted April 16, 2008 i always thought that dual power supply amps where.... one for main power(battery) and ground and the other power supply was just a built in spot for the capacitor... im not sure about the orion but its like that on the MTX TA series With really big amps the maximum current draw is larger than what a single run of 0ga can take... so instead of making us buy 00 or bigger they just have 2 power supplies inside The grounds are usually paralleled internally but you'll find the +12v is probably quite separate. 10.x volts fo' life!
