box needed for 2 GZRW 30SPL
ardo18
Hello, i just bought 2 ground zero gzrw 30 spl subwoofers with a GAS PRO2000.1 amp
I use 25mm thick wood
the subwoofers are
Model
GZRW 30SPL
Diameter
300 mm / 12"
Mounting diameter
281 mm / 11.06"
Mounting depth
150 mm / 5.91"
Voice coil
63 mm Runddraht / 2.5" Round wire
Cone
Verstärktes Papier / Reinforced paper
Power Handling
1000 W SPL Power
Impedance
2 x 2 Ohm
SPL
92 dB
Xmax
20 mm / 0.8"
Fs
33 Hz
Qts
0.36
the specs of the amp are
2000W@1ohm, 1250W@2ohm, 650W@4ohm
is there someone who could design me a nice box for this setup?
Honda accord coupe 1994 USA
The dimensions are 33,5 cm high. 84 cm with and 60 cm depth
thanks
So here is a suggestion needed to go with different dimensions and wood thickness to (barely) meet manufacturer recommendations, you need to verify this will work for you, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 12 cm, figure is just an assembly guide:
NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
  • Who's Online   0 Members, 0 Anonymous, 2269 Guests (See full list)
