brandon6.0 Posted October 6, 2015 Report Posted October 6, 2015 Hey guys im putting a new setup together for my wifes trailblazer ss. Here are the details. Subs: 2 15" American Bass tnt1544 dual 4ohm Amp: Older alpine mono m1005 2000watt max at 2 ohm stable class d. I realized i will will have to run them at 4 ohms with a 800 watt rms. Subs parallel would be 1 ohm. Kinda plan on a new amp your thoughts or recomendations? Im looking for a box for both 15s facing upward. I want port toward rear hatch. Looking for a serious bass setup. Im thinking hz around 30-35??? Listen to rap only. Im a carpenter by trade but figuring these deminsions and ports has me a lil confused. Demensions are: L=46" fender well to well. W= 24" and h= 18-20" I can push it farther back toward the hatch if need be. I think theres another 6-7" there if we need it. Cant wait to see what u come up with. Thanks and appreciate all your help. Great forum!!
brandon6.0 Posted October 7, 2015 Author Report Posted October 7, 2015 Do u guys need any more info? Have not had a reply yet. Thanks.
brandon6.0 Posted October 7, 2015 Author Report Posted October 7, 2015 Here are the sub specs. Subwoofer SeriesTNT (American Bass) Subwoofer Size15" Peak Power Handling1600 watts RMS Power Handling800 watts Voice Coil(s)Dual Impedance (Per Voice Coil)4 ohms Voice Coil Diameter3" Sensitivity92.6 dB Xmax (millimeters)15 mmFree-Air Resonance (Fs)32.2 Hz Equivalent Compliance (Vas)77.2 liters Total Speaker Q Value (Qts)0.549 Electrical Q Value (Qes)0.633 Mechanical Q Value (Qms)4.163
brandon6.0 Posted October 9, 2015 Author Report Posted October 9, 2015 Ok guys change of plans. Imma have both subs and have a alpine mrd 1005 on each one. Im headed to grab another one off craigs list tomorrow. So ill have each amp at 2 ohm on each sub at 2 ohms. Should be clean and clear and sound great!!! Cant wait to crank it up!!
brandon6.0 Posted October 11, 2015 Author Report Posted October 11, 2015 Well since this thread has been up for a week without a reply. Can someone else help me out here? I downloaded torres box building app. I drawed up a few boxes but need help with what hz to tune to? Thanks
Triticum Agricolam Posted October 11, 2015 Report Posted October 11, 2015 Well since this thread has been up for a week without a reply. Can someone else help me out here? I downloaded torres box building app. I drawed up a few boxes but need help with what hz to tune to? Thanks 6-8 cubes tuned to 32 hz should work quite nicely. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
brandon6.0 Posted October 11, 2015 Author Report Posted October 11, 2015 Ok thanks for the reply. I checked out your instagram. U build some pretty serious enclosures! Nice work!
brandon6.0 Posted October 11, 2015 Author Report Posted October 11, 2015 One last thing would any port shape and size be better than another? Like a sloted port 4" high across bottom compaired to a square port 6"x6". Does it really matter? Just as long as hz is tuned correctly. Leaning toward a box like this:
brandon6.0 Posted October 11, 2015 Author Report Posted October 11, 2015 One last thing would any port shape and size be better than another? Like a sloted port 4" high across bottom compaired to a square port 6"x6". Does it really matter? Just as long as hz is tuned correctly. Leaning toward a box like this: https://www.google.com/search?q=enclosure+custom+for+2+15s&prmd=sivn&source=lnms&tbm=isch&sa=X&ved=0CAkQ_AUoAmoVChMI8pDlhcy5yAIVBVg-Ch1nSg0I#imgrc=0gLS55VSyGRc0M%3A
