Triticum Agricolam Posted October 11, 2015 Report Posted October 11, 2015 One last thing would any port shape and size be better than another? Like a sloted port 4" high across bottom compaired to a square port 6"x6". Does it really matter? Just as long as hz is tuned correctly. Leaning toward a box like this: https://www.google.com/search?q=enclosure+custom+for+2+15s&prmd=sivn&source=lnms&tbm=isch&sa=X&ved=0CAkQ_AUoAmoVChMI8pDlhcy5yAIVBVg-Ch1nSg0I#imgrc=0gLS55VSyGRc0M%3A The main thing you want to avoid is high aspect ratio slot ports. The aspect ratio is just the height compared to the width of the port. So if your port was 4" high by 10" wide the aspect ratio would be 1:2.5 Lower aspect ratios are better, ideally you want to keep it under 1:3, though anything up to 1:5 generally isn't a problem, above 1:5 I recommend compensating by increasing the port area and I never go about 1:8. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
