Interesting subwoofer and box reccomendations. Your thoughts?
mcfalcon
Hmmm. Today in my searches of different brand subwoofers I found one with specs unlike any other I've seen. This is a 12" woofer designed for sealed only. The reccomended enclosure size is .6.Re 4.2 ohms
Fs 15.9 Hz
Qes 0.39
Qms 8.9
Qts 0.37
Le 5.7 mH
Sd 467 cm^2
Vas 46.8 L
BL 26.9
Mms 661 g
Xmax (1-way) 38 mm
Xmech (1-way) 50 mm
RMS Power 1350 watts
Found it interesting and would like for everyone to chime in with their thoughts. It says this woofer is designed to smash the lows in a tiny sealed enclosure.
Still learning but have started gathering.
That's the Stereo Integrity HST-12 right?
It's got a heavy cone/coil and loose suspension, which is why the Fs is so low. The loose suspension helps it get the cone excursion required to get good low frequency output with a sealed box.
It's a home theater sub meant to play down to the teens. It's not efficient but it lets you get max output out of minimum space.
Builds:
  • Who's Online   0 Members, 0 Anonymous, 692 Guests (See full list)
