Pedro Valdes Posted October 9, 2015 Report Posted October 9, 2015 Hi Guys, saying hi from Panama! i'm looking fox the best box possible for my Hyundai Tuccson 2009, per the website they recommend 2.66 Cu. Ft per sub. The amp that i'm using is a db drive a4 2400D i mostly play pop, reggae and some rap. My measures are 39 inches width 20-25 inches height 20 inches depth if you could please help me with this i will really appreciate it
Frank H Posted October 11, 2015 Report Posted October 11, 2015 Does the website recommend a port area? Scion xBSinger 275Big 3 OFC 1/0Kenwood ddx492Alpine 4ch f600 - Alpine components SoundQubed 4500 - Sundown Audio X12
Pedro Valdes Posted October 12, 2015 Author Report Posted October 12, 2015 Does the website recommend a port area? Hi Frank. thank you for your reply. This is the information from the website: Ported Enclosure Box Volume 2.66cu ft. Box Tuning 38Hz Port Diameter 2 x 4in Port Length 19in
Joe X Posted October 12, 2015 Report Posted October 12, 2015 Here is a suggestion, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 5", figure is just an assembly guide, only vertical cross braces are needed, can be done with 1 1/4" wooden dowel rods:
Pedro Valdes Posted October 13, 2015 Author Report Posted October 13, 2015 Here is a suggestion, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 5", figure is just an assembly guide, only vertical cross braces are needed, can be done with 1 1/4" wooden dowel rods: Thank you very much I will post a pic when the enclosure is ready!
Pedro Valdes Posted October 19, 2015 Author Report Posted October 19, 2015 Hi Guys! I finish the enclosure and the results are outstanding!!! How can i upload pictures here? another question! i screwed the box completely and besides that i put some wood glue to the box but! there is a phew (minimum) air coming out from one of the sides. can i use silicone or something to cover that ? thank you in advance!
Shenker Posted October 20, 2015 Report Posted October 20, 2015 you will have to upload to a image hosting site, I use photobucket, but there are many out there. it will give you the option to copy and paste images using a URL, you will want to copy the "IMG" code, paste it here, and click post. -If its loud, fast, outrageous, or all of the above, chances are i'll think its awesome. -"No way he's OCD." -said none of the people that know me ever. 04' Suburban "Lucifer" A.K.A #Lucii (Under Construction) 4 10s on 4kW in 6cu net @~28hz /////Alpine Crescendo KnuKoncepts Optima SHCA Build Thread 92' JDM 325i "Stella" ~Going for sale to build a 350+hp E30~ Gutted pipes 96,000 OG KM's (59,000 mi) -System Removed- 1 10 on 1kW 89' Gen 3 Honda Prelude SI AWS "Odis" Bone Stock Possibly going to stance it
Joe X Posted October 20, 2015 Report Posted October 20, 2015 Hi Guys! I finish the enclosure and the results are outstanding!!! How can i upload pictures here? another question! i screwed the box completely and besides that i put some wood glue to the box but! there is a phew (minimum) air coming out from one of the sides. can i use silicone or something to cover that ? thank you in advance! Glad you liked it, here's a tutorial on posting pics here: http://www.stevemeadedesigns.com/board/topic/160056-how-to-post-pictures-on-the-forum-photobucket/
Frank H Posted October 20, 2015 Report Posted October 20, 2015 You can seal the box with silicone. I always do. I am not sure of the truth to this, but its been said that you should let the silicone cure before installing the woofer because the chemical released while curing can eat the speaker surround. I've ignored this plenty of times without problems, but thought Id let you know so you can make your own decision. Scion xBSinger 275Big 3 OFC 1/0Kenwood ddx492Alpine 4ch f600 - Alpine components SoundQubed 4500 - Sundown Audio X12
