Home Made Passive Crossovers...
ptcary
I have a 4 ohm tweeter and a 4 ohm 5x7 mid in the rear of my car, I want add the tweeter to the mid in a series wiring to get 8 ohms to make them a little quieter than the front stage.
How would I go about adding a 3rd order passive crossover to the tweeter to get an 18db roll off below say 5000 hz? I know how to look up the values needed, but not how to wire for a 2 speaker mid and tweeter setup in series?
**EDIT: I have talked with a friend/pro installer, and he is not sure that I can run a passive crossover in a series connection mid/tweet for an 8 ohm load. He is researching this too. I will probably have to get a prefab 2 way crossover and go that route.
Post responses anyway, if you know more about this.
PTCary
2003 SMD PT Cruiser
2011 Honda CBR 250R
2010 Mazda 3i Sport
MY BUILD LOG
http://www.the12volt.com/caraudio/cross.asp
that site has all the info u will need along with a calculator for the values you will need..... good luck
Head Unit: Pioneer DEH-P6000UB
Sub Amp:American Bass VFL 500.1
Subs: 4 Fi BL 18's
Enclosure:21.5 Cubic foot flat wall tuned to 40 hz
Batteries: 3 Kinetik 2400's in the back, Kinetik 1200 under hood.
Mids & Highs: 4 Kicker DS 6.5 coax in doors, 2 Kicker DS coax in pillars
Highs Amp: Kicker kx250.2, kx100.2
Wire: 4 Runs 1/0 gauge Knukonceptz
