2 Memphis Power Reference 12s need enclosure advice
snowman46953
I have two two memphis 15PR12S4V2 that previously lived in a sealed ATRENDS BBOX. It was decent for what it was but I have had problems with the box and took it apart to fix the challenges and found mold meaning the box had gotten wet. So it is obviously time for a new box and I am not sure what route I want to go. I am open to a sealed or ported box. This will be going in the back of a blazer xtreme with the rear seats up. I can measure it tomorrow if that will help but the BBOX is 30.25 inches wide and that was pretty much the max between the spare on the drivers side and the wheel well on the passenger side. The depth is 14.5 and I would say there was about 12 inches to spare there. Height is 13.25 and I would like to keep it around that height as I plan on putting a 3 inch security drawer underneath it and would like to keep things below the seat line. Recommended is 1.25 cubic on sealed and 5 cubic ft for ported. I don't think I would really have room for ported but I have never done this before. Thanks in advance for anyone that can help.
So here is a suggestion, bear in mind they specify gross volume not net so the following should be fine if the external dimensions work for you, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 3 3/4", figure is just an assembly guide:
  • Who's Online   0 Members, 0 Anonymous, 986 Guests (See full list)
