finally figured out my space, subs, now confused with port area.
cocoleveo7686
What's the reason you want a little bigger enclosure?
More output?
Shrinking the port will lower the output.
Yea but isnt it better to have a little more spaace than port area? What do you suggest
It's not that simple, whenever you change net volume you are going to change output. Once you have enough port area, adding more wont change anything. My priorities when designing boxes is to have the right amount of port area first, even if it means having a little less net volume than I'd like. Once there is the proper amount of port area then you can focus on getting more net volume, if desired.
Just curious, how do you determine port area?
Modeling, xmax/tuning calculations or a general sqin per cuft?
More output?
Very informative. Thank u. Even though they recommend 1.5 cubes lets say out of curiosity i threw it in a 2.25 cube box it would have more output correct? But be more peaky at tuning?
Yup, that's pretty much it. As you make the box larger you will get more output but only around the tuning frequency. This can make the output more peaky. Also as you make the box bigger cone excursion increases so you have to keep mechanical power handling in mind.
Builds:
[quote name="db_speakerbox" post="3049792" timestamp="1448019982"
There are formulas based on Xmax, net volume, and tuning frequency you can use, but my preferred method is using modeling software.
Builds:
Ok. I use the calcs as a starting point then just test and test some more.
I assume you use hornresp?
Yeah, Hornresp and WinISD depending on the particular application.
Builds:
  • Who's Online   0 Members, 0 Anonymous, 3081 Guests (See full list)
