Donovan Escaleras Posted November 21, 2015 Report Posted November 21, 2015 Im building a box for a friend of mine and the subs he has have specs for a ported box but its an aero port i want to do a slot port. I dont know how to do design ported boxes. the subs are 2 crossfire P110D's. Available space is 38'W x 15"H x 16'D.
Joe X Posted November 22, 2015 Report Posted November 22, 2015 So here is a suggestion best for a trunk car, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 2 3/4", figure is just an assembly guide:NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
Joe X Posted November 22, 2015 Report Posted November 22, 2015 You're welcome, just curious, what's the vehicle?
Donovan Escaleras Posted November 25, 2015 Author Report Posted November 25, 2015 Joe X its a 2016 vw golf tsi
Donovan Escaleras Posted November 25, 2015 Author Report Posted November 25, 2015 and are the measurements you gave me in accordance to the picture like as far as where everything goes, and how it should go together? I know its not to size. The reason i ask is because I sketched it up in google sketch up and the sides cant both be 13 1/2 x 13 1/2. Also is the port supposed to be 2 3/4'' wide the whole way through? Cause in my model its 1 3/16 wide on the back wall but it is 2 3/4" in the beginning portion of the port.
Joe X Posted November 25, 2015 Report Posted November 25, 2015 and are the measurements you gave me in accordance to the picture like as far as where everything goes, and how it should go together? I know its not to size. The reason i ask is because I sketched it up in google sketch up and the sides cant both be 13 1/2 x 13 1/2. Also is the port supposed to be 2 3/4'' wide the whole way through? Cause in my model its 1 3/16 wide on the back wall but it is 2 3/4" in the beginning portion of the port. The cutsheet is now updated for the assembly style that matches the pic, my apologies.
Donovan Escaleras Posted November 25, 2015 Author Report Posted November 25, 2015 thanks i really appreciate it joe
Alex Leonard Posted November 25, 2015 Report Posted November 25, 2015 how long does it take you to design a box like that joe?
