LoudPackRacing Posted December 12, 2015 Author Report Posted December 12, 2015 Yup. I use titebond 2 for glueing the wood together, then run liquid nails along all of the seams. As long as you let the caulk cure for a couple days it will be nice and solid. I use titebond as well the blue label.
LoudPackRacing Posted February 12, 2016 Author Report Posted February 12, 2016 Here is a suggestion, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 3 1/4", figure is just an assembly guide:NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside. I'm looking to rebuild the current box above a little smaller and using aero ports. I was shooting for 3 cubes.I will be using a Rockford P1000x1bd @1ohm I heard they put out around 1400 rms on proper electrical. Max demensions 34" width 16.5" or 16.75" height and 18 depth sub and port forward. I built the box above and do like it but I'm going to be using birch this time and trying to go a little smaller in size due to power.
