15" fi ssd box design
LoudPackRacing
I need a box design for a 15" Fi SSD to go in my 2003 civic coupe. I will be running it off a 02 kicker kx1200.1 @1ohm. Max deminsions 17.25 height 34 width and 20 depth port and sub forward
Here is a suggestion, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 3 1/4", figure is just an assembly guide:
NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
Here is a suggestion, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 3 1/4", figure is just an assembly guide:NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
How wide should the 45s be?
Fiberglass isn't necessary for this box. As long as the glue joints are good and strong it will be fine.
If you want you can also run caulk along all of the seams to ensure they are sealed. If you do that, just remember to give the caulk a few days to cure. The fumes the caulk puts out can damage the soft parts of a sub if you don't wait till the caulk is cured.
Fi Team 18's (4)
Crossfire 16k
Crossfire 400.4 & 800.4
Pioneer AVH-X491bhs
140ah cmax
CES 320's (2)
I normally use liquid nail heavy duty caulk the brown stuff. Is this fine?
Yup. I use titebond 2 for glueing the wood together, then run liquid nails along all of the seams. As long as you let the caulk cure for a couple days it will be nice and solid.
Fi Team 18's (4)
Crossfire 16k
Pioneer AVH-X491bhs
140ah cmax
CES 320's (2)
  • Who's Online   0 Members, 0 Anonymous, 549 Guests (See full list)
