mmacleod1983 Posted December 3, 2015 Report Share Posted December 3, 2015 I was clipping, having bad voltage drop and dimming lights installed a subsonic filter and eliminated almost all of the voltage drop and light dimming Question is... If your box is tuned to 35hz like mine is, and you listen to lots of music that is lower than the tuning of your box, how does this effect amp performance? I notice big drop in performance on the low end around 25-30 hz and this is when clipping seemed to happen. I know this is common in ported boxes but its a prefab fox box and I cant change the tuning as far as I know. I have new subs and a larger amp on the way. Im hoping more power and effeciency may play my subs louder and not strain my electrical system as much. AM I wrong in this way of thinking? Am I still going to clip if I overpower the subs and match gain my amps to subs? I need lower than 35hz but dont want a new box since I already shelled out $225 for this one and need my back seat. I see videos of this exact box on youtube and playing similar songs quite well. SO im hoping there is a solution besides a new box Link to comment Share on other sites More sharing options...
andru Posted December 3, 2015 Report Share Posted December 3, 2015 playing below tuning freq can make you subs unload and blow, if you like the box maybe look into if you can modify it and extend the port to a freq you like more Link to comment Share on other sites More sharing options...
rfbasshead Posted December 3, 2015 Report Share Posted December 3, 2015 what equipment are you using? Link to comment Share on other sites More sharing options...
bman8891 Posted December 3, 2015 Report Share Posted December 3, 2015 If your existing box has a regular slot port you can build an insert to shrink your port area which will lower tuning. If it has aero ports just make them longer Link to comment Share on other sites More sharing options...
