DD-1 with Pioneer?
When using the DD-1 to set the gain on a sub amp, should the sub level on a pioneer headunit be at +6 to get the full voltage from the headunit? Also, should I have my LPF at the max setting on the amp when setting the gain?
If it's sub level, I always had mine turned up, if you're talking bass boost or bass level on the HU then no. Keep it level. I had mine maxed but I had an alpine so there is a difference.
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
just find max undistorted with track 2 on your mid range outputs. Then play track 1 for your sub out at the same volume and turn up sub out till you find distortion then back it off one click if needed.
edit:
this is pretty much standard procedure for all headunits with sub out adjustments.
Edited by strangeduck
  • Who's Online   0 Members, 0 Anonymous, 1421 Guests (See full list)
