Posted (edited)
Because they are 6 volts not 12
:blink:
Which has more amps tho? Because if you run 6v batts in series then you're getting 12 v but not the amperage.
Edited by mrrairai
Member since 25 Jun 2006
2011 Yukon DenaliCustomLightz 4300K HID RetrofitEsky TailsEsky Third BrakeEsky 22sEsky Appliques
Guest Powered By Hate
:blink:
or making giant 18v batteries outta many 6v's.
one reason is , if youre over 18v you wont qualify to compete, you voltage has to be 18v down...(unless theres something in the rules i missed)
Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
If you're AT 18 is that ok? heh? 18.0?
3 - 6 volt batts would be 18.99 volts.
Michael Hughes = 6X SPL World Champion - Loudest on the planet in db Drag, USACi, and IASCA.
So I gotta get race car batts =[ or 8v's..
18.0 not 18.1 not 18.01 but 18.0volts or youre dq'd on the spot
  • Who's Online   0 Members, 0 Anonymous, 6871 Guests (See full list)
