Box volume
Jacobv55
You can't know the net volume without the driver displacement of the sub being used so thinking of a 15" (which would work in that box size) and setting it's driver displacement to 0.2 cubic feet, the box specs would be 3.8 net @ 39.8Hz with 81 square inches of port area.
Oh ok, I was just confused about the cubes because I tried 3 box calculators and I got all diffrent cubes from 3.9 to 5.8 cubes net. So 3.9 is correct for those dimensions? Thanks
3.8 net with a 15" driver in as above and about 4 cubic feet without any driver in the box. If you say 3.9 that's pretty close.
It's the manufacturer recommended net volume, depending on power you are using and your goals you could change that to fit your needs, one thing that seems a bit high is your tuning which may not work good on low tuned stuff like rap and such.
  • Who's Online   0 Members, 0 Anonymous, 8279 Guests (See full list)
