Recommendations with my system
I just bought a dd-1 & cc-1. I'm pretty sure I can figure out how to use them but not sure what I should set my frequencies at. What would you recommend? I listen to all kinds of music but mostly stuff that has a good beat. I'm not the swiftness guy out there when dealing with electronics so please dumb it down for me.lol. Thanks
Here's my setup
Headunit kenwood dnn991hd
Front speakers HD-61proCR
Rear speakers HD-6EX
Subwoofer 12" W7
Front/rear amp alpine pdx4.150
Sub amp alpine pdx 1.1000
If you're using that, that means you're running passively. So the only thing you need to use the CC-1 on is your sub amp. Set your sub amp's LPF to 125hz to start, and adjust down from there to your likeing. do you have a ported or sealed enclosure? If ported, what is it tuned to?
Ported tuned to 36.7 hertz or that's what it claims.
Ok. I'm not sure if that amp has an adjustable subsonic filter (or infrasonic). If it does, you can set that to 28hz.
On your mids/highs amps, set all crossovers to full pass since you're using the passive crossovers.
For the DD-1, I like to use the -10dB 40hz tone (track 5) for my sub amp, and then I use the -5dB 1khz tone for my mids
Thanks
Thanks
No problem. If you need any other help, let us know :)
