miniSPLlancer Posted January 11, 2016 Report Posted January 11, 2016 I use to compete with this 15, scored a 151.3 meca with it. Quit car audio after that, accomplished what I wanted to and called it a day. Gave the sub to a buddy, he had it for about month and then said it stopped playing. I thought he fried the coil, clipping the signal even though I tuned everything for him. He gave it back to me since it isn't working anymore, I tore it apart, the reason it was stuck, he shifted the motor. He says it must've been from me, of course LOL. But my reason for this post, The coil looks minty as hell for having multiple 10k burps and beating the hell out of this sub at full tilt for the year I had it installed. Ran 2 Soundqubed 3500's @ .25 ohm each. Say what you will, but I'm impressed with the build quality of this sub. I've ran this sub in 4ft3 at 35hz, burp box @ 53hz, music full tilt on both setups and it held up very well. 2011 Mitsubishi OutlanderSony 712 Soundqubed HDS208 Alpine MRV-M500 Transmission line enclosure Soundqubed wiring Knu rca XS Power battery CNF terminals
ShadeTreeMechanic Posted January 12, 2016 Report Posted January 12, 2016 I have a pair of the HDS315s and love them. Were your 3500 amps strapped? How did you get .25 ohm? 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
miniSPLlancer Posted January 12, 2016 Author Report Posted January 12, 2016 I have a pair of the HDS315s and love them. Were your 3500 amps strapped? How did you get .25 ohm? Amps were strapped and sub was Dual 1 2011 Mitsubishi OutlanderSony 712 Soundqubed HDS208 Alpine MRV-M500 Transmission line enclosure Soundqubed wiring Knu rca XS Power battery CNF terminals
ShadeTreeMechanic Posted January 13, 2016 Report Posted January 13, 2016 Epoxy looks good for a copper coil. Are those amps rated for .25? Do you plan to rebuild? 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
miniSPLlancer Posted January 13, 2016 Author Report Posted January 13, 2016 Epoxy looks good for a copper coil. Are those amps rated for .25? Do you plan to rebuild? Rated at 1 ohm, easily .5 ohm, and .25 ohm responsibly. No rebuild, I'm done with that scene in my vehicle, spending that money on more important things now, willing to help friends with their builds. Aluminum coils BTW 2011 Mitsubishi OutlanderSony 712 Soundqubed HDS208 Alpine MRV-M500 Transmission line enclosure Soundqubed wiring Knu rca XS Power battery CNF terminals
ShadeTreeMechanic Posted January 13, 2016 Report Posted January 13, 2016 Aluminum, my bad. The epoxy fooled me. LOL! 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
miniSPLlancer Posted January 13, 2016 Author Report Posted January 13, 2016 My old build 2011 Mitsubishi OutlanderSony 712 Soundqubed HDS208 Alpine MRV-M500 Transmission line enclosure Soundqubed wiring Knu rca XS Power battery CNF terminals
